42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Revit to Lumion
Hi All,
I've modeled a parametric louver as a part of the building skin for a project.
I am unable to import the louver into lumion for rendering. Rest of the model gets imported completely.
Does anyone have any idea regarding this?
I'm using Revit 2014 with Lumion 4.5
Thanks
I think there needs to be a little bit more info to diagnos the issue. I'm not familiar with using lumion, but I imagine you having to export in some format to be able to use in lumion. If that's the case, depending on those settings, your louver might not be included because some layer or categorization. There could also be a workset, design option, phase, generic model versus other category issue that may not be supported by lumion. Explain a little bit more about what this element is, how it was modelled and instantiated in your project prior to export, as well as what your procedure for export is and hopefully that will help arrive at a solution for you. Cheers.
Revit to Lumion |
Fri, Jun 27, 2014 at 3:46:16 PM
Lumion 4 Sneak Peek |
Mon, Oct 14, 2013 at 12:46:51 PM
lumion graphics card use |
Tue, Dec 2, 2014 at 2:03:22 AM
Revit to Lumion |
Tue, Jun 18, 2013 at 6:16:24 AM
Revit to Lumion |
Tue, Apr 14, 2015 at 2:17:56 PM
Members: | 2000388 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
