50 Users Online (49 Members):
Forums >> Revit Structure >> Technical Support >> masking regions overlap other views in sheet?
140 Posts No Rating |
Hey everyone, I unfortunately have many coordination drawings that were made in autocad and are being requested to be on the Revit draings. I was hoping to link the .dwg file becasue they will continue to be used for coordination. I plan on not placing them in the "model" and simply drawting views.
I recall a post years back about how to mask unwasted regions with essentially a masking region that has a whole in in. So I made my drafting views and linked in my cad files (the cad file is a true model space which has many views and paperspace layout tabs and I was hoping to continue with this) and applied the masking region, which is quite large.
However, when I place my revit drafting views onto sheets, the masking region from one view is masking the elements in other views which I was not anticipating. Does anyone have a solution for this (if I was clear enough) or a bettter way of getting this task done.
Any thoughts are appreciated.
Greg
Any view on a sheet has priority by the order they were placed. For example, if you put VIEW 1 on a sheet first then VIEW 2, VIEW 2 will sit over or mask VIEW 1. Now if you add a VIEW 3, VIEW 3 will mask VIEW 1 and VIEW 2.
Thanks for the reply. I figured that was happening. I just wondered if there was a way to prevent masking regions within views from masking other vierw elements or if there was a better way to crop drafting views.
Can I have an AutoCAD layout tab linked inside a drafting view?
G
Exporting to Autocad with Masking Regions |
Thu, Apr 25, 2013 at 10:33:27 AM
11
Masking Regions not "masking" |
Mon, Dec 14, 2009 at 11:21:22 PM
Mysterious masking regions showing up on plot |
Wed, Sep 17, 2014 at 10:31:28 AM
Masking region appear grey in consistent color views |
Wed, Feb 15, 2012 at 2:49:06 PM
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:55 PM
Members: | 2005678 | Objects: | 22910 | Forum Posts: | 152188 | Job Listings: | 3 |
