63 Users Online (61 Members):
Forums >> General Discussion >> Revit Project Management >> How to take quantities from painted surfaces?
Hi,I would like to take out the quantity of the painted surfaces in a project. I have considered using the "paint" tool and pain all the surfaces. However some of the wall are not painted all the way to each floor partition, because of suspended ceilings. Whats the work around that? Or do you have any other suggestions?
You would have to use the split face tool to paint the correct area then use the materials take off. If all of your walls are the same, you can build your wall type with a split in your finish face at a set elevation.
Thanks - That solved it
Try using the Revit Roombook plugin. It is availalbe via Subscription.
----------------------------------- Rick Feineis, CTT+, AAI Managing Partner CAD Training Online (757) 619-3614 www.cadtrainingonline.com |
Use the extension name colorzilla for taking quantity of painted surfaces.
Revit 2014 . rendering in cloud . painted surfaces |
Mon, Feb 23, 2015 at 4:13:00 PM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
Painted surfaces |
Wed, Jul 17, 2013 at 10:06:53 AM
painted split face doesn't show in dependent view |
Mon, Nov 1, 2010 at 12:32:13 PM
Really Odd Perspective/3D problem |
Wed, Apr 29, 2015 at 7:53:09 AM
Members: | 2000402 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
