50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Rendering Trees and other RPC items in Revit 2017
I just installed Revit 2017 from 2015, so I loaded a previous project to see the new rendering capabilities and none of the trees or people render, In fact most of them just show as blocks or cubes. I even loaded a new project and new families straight from the 2017 templates folders and I still get the same results.
Edited on: Wed, Apr 20, 2016 at 1:03:48 PM
Update*
I installed Revit on a fresh computer and everything is working fine, I believe it has to do with running previous versions of Revit on the computer, yes I installed 2017 before removing 2015 I've attached files to help clarify things
We have not yet installed 2017 - we typically only install a test version on one machine then wait until after the first update to assure that most bugs are resolved.
That being said, Revit has typically never been affected by older versions. Our license allows for us to use 4 different versions so we always have 4 versions installed on all machines. You typically never want to assume that your consultants will be on the latest version of revit and we typically never upgrade a project after CD's have started.
Uninstalling previous versions may have been your problem because some of the pointers may have been lost.
Revit 2012 problem rendering RPC trees |
Tue, Sep 6, 2011 at 5:26:07 AM
Rendering Trees in Revit 2010 |
Wed, Apr 27, 2011 at 2:53:37 PM
Very Slow Rendering (many RPC trees) |
Tue, Apr 13, 2010 at 3:47:25 AM
RPC trees not rendering - but show in model |
Fri, Mar 2, 2012 at 7:32:16 AM
Rendering RPC issues |
Thu, Jun 11, 2009 at 3:55:31 PM
Members: | 2068581 | Objects: | 23093 | Forum Posts: | 152257 | Job Listings: | 3 |
