50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Line Weigths in Families
Fri, Feb 5, 2016 at 1:01:01 PM | Line Weigths in Families
CDWdavid
5 Stars: 5 Votes
Does any way to set up different line weights in families?
Please see the attached Door Window Legend, they are all families.
Thanks!
Fri, Feb 5, 2016 at 1:33:34 PM | Line Weigths in Families
CDWdavid
5 Stars: 5 Votes
Figured it out, I can use subcategories.
Sun, Feb 21, 2016 at 6:51:46 PM | Line Weigths in Families
palladio1234
5 Stars: 3 Votes
Yes subcategories and if you want you can create different line types within your family.  When you import the family into your revit model you can adjust the line weights under the object styles (OS) for project wide changes or visibilty graphics (VV/VG) dialog for view specific changes.  Just make sure you put your family in the correct category so when you import it you know where to find it in the object styles or visibility graphics dialog to adjust line types you created in your family.
Good Luck!
-Erik
Line-Based Detail Families - Pick Line Option Gone?!?!
Mon, Sep 5, 2011 at 8:25:00 AM
Break Line & Weld sybol families
Wed, Apr 28, 2010 at 9:18:41 PM
Grouping Line-based Families
Mon, Oct 30, 2006 at 12:00:45 PM
Line Type Families
Thu, Nov 27, 2008 at 1:34:52 AM
How the heck can I get line styles to Families?
Mon, Apr 14, 2014 at 11:21:58 AM
Page generation time: 0.8220
