48 Users Online (47 Members):
Forums >> Workflow & Implementation >> Training >> why my levels have associated to objects,
I am having an issue where if i delete a level that i have created who have seem to have assocaited with other components in the project and so get deleted also along witht the level. how can i delete the level only and or disassociate it with the other components in the project.
Thanks guys.
There are many objects in Revit that may be associated with levels. You would have to re-host each one before deleting that level. So obviously, levels should be well though out ahead of time.
What you can do,
- Hide that level in views
- Put the level in a workset that is off in all views.
Combining objects that are on two separate levels at the same elevation |
Fri, Sep 25, 2009 at 10:20:23 AM
Select All Objects by Referenced Level? |
Mon, Jun 5, 2006 at 5:14:28 PM
Auditing Levels |
Sat, Apr 9, 2011 at 5:17:06 PM
Showing objects in higher levels in hidden linetype |
Tue, Feb 21, 2012 at 7:10:07 AM
deleting levels without deleting associated objects on it. |
Thu, Aug 1, 2013 at 6:20:35 AM
Members: | 2000224 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
