45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Creating sketches - short cuts
Wed, Aug 19, 2015 at 1:22:03 PM | Creating sketches - short cuts
3.5 Stars: 395 Votes
If you need to sketch a complicated shape for anything, look to see if you already have that shape in a different sketch.   For instance:
  • A complicated floor or ceiling sketch
  • A profile
  • A filled region
  • A masking region.
  • Simple linework - even from imported CAD
  • A model element - see special below
Many sketches can be copied to clipboard and pasted into new sketches.  As an example, you want to place a filled region over an entire plan.  If the floor is sketched to the same limits, simply edit the floor sketch, window it, copy to clipboard and close the sketch.  Now start your filled region and paste in.
Another advantage is the pasted sketch is scalable.  Lets say you want to sweep a crown mold around a room but you don't have the right crown mold profile.  You can open your crown mold profile family, copy the linework to clipboard and paste into your project then scale it.
On occasion, you might run into the "can not copy between project and family" error but not that often.
SPECIAL - For model shaped elements, you can export a view to CAD to make it all be linework then import and use that.
Thu, Sep 3, 2015 at 1:12:58 AM | Creating sketches - short cuts
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Pasting the sketch lines from the sketch mode of a floor or roof into a filled region etc is a great tip. Thx
Short cuts
Sat, May 5, 2007 at 11:09:48 PM
can't customerize my own short cuts on 64bt machine
Tue, Jul 27, 2010 at 3:36:23 AM
Wall Sweep Overlaps window frames and cuts (some not all)
Mon, Jun 22, 2015 at 8:02:14 AM
creating masses
Fri, Jun 30, 2006 at 7:40:04 AM
Detail Cuts
Wed, May 3, 2006 at 5:03:48 PM
Page generation time: 0.5251
