96 Users Online (95 Members):
Forums >> Community >> Newbies >> Window elements not showing in one elevation.
I am working on a project where I have the same windows in the same wall types but in one elevation all of my elements are not showing, (i.e. the muntins and window sill). I have attached a drawing. Can someone explain why this may be happening and what I can do to fix it. I have highlighted in red what I am talking about.
Thank you!
This is most likely user error but that is hard for us to pin down. I suggest you look at the following: Don't just say yes - examine.
- Is the view depth deep (elevation) enough to show all of the window?
- You have the vertical muttins but not the horizontal. That would indicate to me that the windows are NOT the same.
I really can't come up with any more since the muttins partially show. It has to be #2.
...also, I've noticed that visual style settings are different. It is set to coarse in the elevation in question. Make them all the same, see what happens. Depending on how the the window family is built, it could make a difference.
Good catch pijpiwo.... More than likely, you are correct. Inconsistant family rules.
That was it! Thank you!
just close eandre-open the drawing
Window Swings Not Showing In Elevation |
Fri, Nov 2, 2007 at 1:01:47 PM
Phasing Issue - Proposed Elements showing solid white |
Thu, Sep 3, 2015 at 7:36:04 AM
Door and Window Frames not showing in Elevation |
Thu, Dec 17, 2015 at 4:34:06 AM
Elevation View for Window Schedule Not Dimensioning |
Fri, Sep 12, 2008 at 3:01:09 AM
Exterior wall brick showing in window |
Tue, Sep 7, 2010 at 12:59:13 PM
Members: | 1998817 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
