47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Revit 2016
Mon, Jun 29, 2015 at 10:34:49 AM | Revit 2016
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
So with the disappointing release of 2016 I am curious if anyone is spending the time to go through and upgrade all of their stuff from 2015 to 2016.  Am I missing something in this realease that would make it worth the time and effort to upgrade (other than if you're collaborating with someone using 2016).
Tue, Jun 30, 2015 at 12:19:44 PM | Revit 2016
surfingjp
I think the new familys are worth it alone!!!
Tue, Jun 30, 2015 at 12:40:04 PM | Revit 2016
3.5 Stars: 391 Votes
We have not yet installed 2016 anywhere.  I usually work with it first and we install sometime after the first update.
I don't know what 'new families' they may have.  I always upgrade our library for our modified families using the upgrade script provided by autodesk.  We keep those seperate from the stock items.
Tue, Jun 30, 2015 at 1:06:07 PM | Revit 2016
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
surfingjp what new families are you talking about?
Mon, Jul 6, 2015 at 12:17:26 PM | Revit 2016
surfingjp
There are almost 1000 new familys. Lots of new doors that are very adjustable.
Mon, Jul 6, 2015 at 1:29:53 PM | Revit 2016
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
There seems to be an issue linking Revit to 3dsMax in 2016, so if you do that, be advised.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Fri, Jul 10, 2015 at 8:42:08 AM | Revit 2016
anniesmith
Hi,
I think its help a lot for using Revit 2016
https://www.youtube.com/playlist?list=PLY-ggSrSwbZq-U8uu0uCIdzf0omMgtzc_
Thanks,
Sd-Academy
Wed, Nov 4, 2015 at 5:38:30 AM | Revit 2016-R2
ppinc
Hi All
Been a while since i posted. Am in need of some assistance please. Have installed  Revit 2016 R2 and it has some great features....BUT the background processes tool that has been added is causing endless nightmares. When this 'feature'is running you are not able to save locally or to Central and you are not able to print when it is running either. Autodesk help files and literature as usual just provides what the tool does and there is no way to disable it. This is really hampering productivity. Has anybody else experienced this issue yet and been able to come up with a solution. My only alternative at this point is to uninstall the update....oh and yet again well done Autodesk, you cannot just uninstall a service pack update you have to uninstall the whole f****** program.
Any ideas anyone?
Wed, Nov 4, 2015 at 9:09:03 AM | Revit 2016
Have you posted this problem directly to Autodesk?  They answer very quickly.
Thu, Nov 5, 2015 at 12:39:43 AM | Revit 2016
ppinc
Hi WWHub
I have posted directly to Autodesk but have yet to receive a response. I had to go the uninstall and re-install of Revit route as production deadlines were being affected.
The background processes tool works fine on small jobs where the colourfill legend does not require huge computational power, however the 2 projects affected (High rise tower and massive retail complex) contained hundreds of rooms and the background process of computing these never seems to end.
will keep Revit city in the loop when we find a solution or best practices option.
Wed, Mar 30, 2016 at 6:21:24 PM | Revit 2016
sllana
5 Stars: 2 Votes
in revit 2016 I can not walk with the "look" option of the navigation wheel. Am I right? or must can.? Always the newer programs are worse than the preceding, they just change things just to say they did somthing.
Edited on: Wed, Mar 30, 2016 at 6:22:15 PM
Thu, Mar 31, 2016 at 8:15:36 AM | Revit 2016
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-60161489-4C2C-41A4-A3DF-1E206F46D605
Thu, Mar 31, 2016 at 11:00:08 AM | Revit 2016
#13
sllana
5 Stars: 2 Votes
oh jesus, it was the nav speed, thanks a lot, im sorry.
Massing appears when exporting from revit 2016 to navisworks 2016
Tue, Feb 2, 2016 at 11:28:30 AM
REVIT 2016 R2
Thu, Dec 10, 2015 at 5:18:21 AM
Revit 2012 to Revit 2016 - Removing Ghost Surfaces Visualization Effect
Thu, Mar 31, 2016 at 10:00:40 AM
Is it possible to Extrude a 2-D profile as a sweep in a Revit 2016 LT project?
Sat, Dec 12, 2015 at 3:58:54 PM
Revit 2016
Wed, Apr 15, 2015 at 7:27:13 AM
Page generation time: 1.8532
