85 Users Online (84 Members):
Forums >> Revit Structure >> Technical Support >> Spot elevation target symbol
0 Posts No Rating |
I would like my spot elevations (in plan) to be a little more compact.
So I made a copy of the spot elevation target family and scaled it down. Also I made masking areas for the white quadrants to make the symbol opaque. Then, in the type properties for my spot elevation, I set the symbol to use my new family.
All is good, except that the crosshairs are still the original size. Damned if I can work out where it picks the crosshair dimensions from. Any suggestions?
0 Posts No Rating |
Try scaling down the Spot Elevation-Crosshair family and see if that works!
0 Posts No Rating |
I can't see a crosshair anywhere in my families.
Screenshot attached.
0 Posts No Rating |
Actually, I just tried creating a new project and it has a Spot Elevation - Crosshair family, so this is something I have purged from my projects at some point.
If I try to edit this family there is nothing there to scale - it is a blank symbol basically. Clearly the crosshair is not part of the symbol.
Okay, I have achieved something close to what I wanted by setting the symbol to "none" and the leader arrowhead to "filled elevation target 4mm" and then changing the arrowhead settings to make the arrowhead 2mm instead of 4mm. I would still like to know how I can control the crosshairs on the spot elevation because a) the white part of the target arrowhead is not a mask and b) it is faster to place spot elevations without a leader
Target size of Spot Elevation (Revit Architecture 2008) |
Wed, Aug 6, 2008 at 9:43:56 AM
Target size of Spot Elevation (Revit Architecture 2008) 2 |
Thu, Dec 18, 2008 at 11:21:25 AM
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:55 PM
elevation target arrow head |
Thu, Apr 3, 2014 at 1:21:54 PM
Spot Elevation Forced Text |
Fri, Apr 22, 2011 at 1:04:00 PM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
