77 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> Grids on circular building not showing in elevations
7 Posts No Rating |
Hi,We are doing some work to an existing circular building with radial grid lines. See attached plan showing grids. When viewing elevations the grids do not show because the view is not perpendicular to the facade. Is there a way to view the entire facade as a true elevation?
RegardsBrent
7 Posts No Rating |
Revit 2015
"True elevation" is what you get from Revit but you don't want that.
There have been discussions here in other threads about this but I only found one:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21990
7 Posts No Rating |
Thanks WWHub.
Building Not Showing in North/West Elevations |
Mon, Aug 18, 2014 at 11:44:38 AM
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
Grids not showing up? |
Fri, Jan 6, 2012 at 1:44:05 PM
columns grids not recognized |
Wed, Oct 6, 2010 at 9:55:29 PM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up |
Wed, Nov 23, 2011 at 1:27:06 PM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
