46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Mass Modelling Dilemma
Wed, Apr 8, 2015 at 10:20:46 PM | Mass Modelling Dilemma
Akua
Greetings group,I'm trying to mass model a building in the shape of a star/pentagon. it consist of a void capped with a skylight. i managed to model the void but i'm having problems modelling the skylight above for the analysis.Any recommendations?The following model shows what i have achieved so far:https://app.box.com/s/w9aq9uzmz1o39rktzsgsvo6z4onryrzdAnd this is a picture to show how the area is intended to look:https://app.box.com/s/zkultkjbd8x2vfj1j2cxmy9q2e6qefst
Thu, Apr 9, 2015 at 8:36:31 AM | Mass Modelling Dilemma
3.5 Stars: 395 Votes
Those links will not work in our office because they are both through linked-in.  You are better off to post the image or a compacted project file here.  We have a 2 meg limit so if you want to post the project file, remove everything else and purge (3 times in succession) then save and post.  The file should easily be small enough.
For image files, the built in snipping tool from your operating system is great.
Thu, Apr 9, 2015 at 9:56:02 PM | Mass Modelling Dilemma
Akua
Fri, Apr 10, 2015 at 7:49:48 AM | Mass Modelling Dilemma
Just create a seperate mass there and create a roof by face - sloped glazing. Then turn off that mass.
cut mass
Mon, Apr 27, 2015 at 9:50:59 AM
Problem in working with mass
Thu, Mar 18, 2010 at 3:59:29 PM
Custom slab modelling issues
Thu, Oct 29, 2009 at 7:25:09 AM
How do you model complicated exterior masonry trims around building entries?
Wed, Jul 13, 2011 at 11:17:24 AM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:54 AM
Page generation time: 0.3877
