61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> materail surface patterns
1 Posts No Rating |
We are using material surface patterns on several exterior wall conditions. But when revising the material pattern under setting/material/appearance/surface pattern, some walls change and some do not. Has anyone experienced the same problem?
This has happened to me, but I figured out that I was overlooking a small detail, the exterior wall face was facing the interior of the house. So you may want to check that this has not happened.
not sure if anyone will see this and respond but did you figure out what the problem was for sure? i am using 2008 and I have a brick pattern i am updating and it is changing in some spots but not others. brick material is the same and my walls are rightside out. any suggestions?!?!? thanks
5 Posts No Rating |
did you find a solution to this? I have a Terracotta wall I want to change the size of the pattern in a shaded view and can't find a way to do it.
Surface Patterns in Perspective |
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns |
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
No Surface Patterns in Perspective |
Thu, Feb 1, 2007 at 4:55:53 PM
surface patterns and rendering |
Sun, Jun 27, 2004 at 7:37:47 AM
Members: | 2000426 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
