60 Users Online (59 Members):
Forums >> Revit Systems >> Technical Support >> Location of Pipe
7 Posts No Rating |
Dear All
I am a newbie in Revit System. I use Revit V2014 when i create Pipe for SAN system. I set up VERTICAL JUSTIFICATION to Bottom and i setup reference level -800 from level.
When i check by section the dimention is show number in difference as i set it up. If i back to select Pipe to change to -800. The dimension in section as i create is shown in wrong value as i create in pipe property.
Have anyone can explain for me please how come is show like that.
Note: The image i attach is shown step what i did.
Thank you very much for your kind.
I'm pretty sure that since all pipes are centerline controlled that the offset property is always to the centerline.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-54B16217-68F4-4F0C-928C-505690B44EFB
7 Posts No Rating |
WWWHub
Thank you for your kind for explain for me. That is make me crystal clear for develop my skill.
Billion Thanks.
Labeling/Schedule Piping per Room Location |
Mon, Jun 23, 2014 at 6:54:45 AM
Trim HSS Round pipe into another HSS Round pipe |
Tue, Apr 3, 2012 at 4:39:45 AM
pipe dimensions |
Wed, Dec 2, 2015 at 7:47:03 AM
Pipe Accessories and Pipe Type parameter |
Tue, Dec 27, 2011 at 11:25:39 AM
Pipe Branch Takeoff/Gain |
Fri, Feb 26, 2016 at 12:29:37 PM
Members: | 2000453 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
