58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> perforated brick screen wall
Thu, Oct 30, 2014 at 1:28:39 PM | perforated brick screen wall
vinnygolfer
4.5 Stars: 4 Votes
hi. i'm using Revit 2014. i'm trying to draw a screen wall around the cooling tower yard. the only thing that i have done that looked even close, was to put a ton of wall openings in the walls. but by doing that, it slowed my computer almost to a stand still. i need a better option.
thank you in advance.
Try to learn at least one new thing every day
Thu, Oct 30, 2014 at 1:54:34 PM | perforated brick screen wall
3.5 Stars: 395 Votes
What kind of screen wall - you don't say? .... and you should
Is it a louver screen wall?   Then place louvers in a wall
If it is a material with holes in it, then assign a material like that to a layer of a wall.
....oops - missed the title. .... just a minute
Edited on: Thu, Oct 30, 2014 at 1:55:24 PM
Thu, Oct 30, 2014 at 1:57:42 PM | perforated brick screen wall
Check out my post here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=33312
Thu, Oct 30, 2014 at 2:08:45 PM | perforated brick screen wall
vinnygolfer
4.5 Stars: 4 Votes
i'm sorry, i thought that i did. it's a Brick wall. and basically it would have bricks missing to let the air pass through for the cooling towers. the wall may have 2 hundred openings in it. that is why Revit almost crashed.
Thu, Oct 30, 2014 at 2:14:29 PM | perforated brick screen wall
Look at my second post...... That was two walls, one in front of the other - you would have the single wall.   Uses one -in place void.
Thu, Oct 30, 2014 at 2:38:15 PM | perforated brick screen wall
vinnygolfer
4.5 Stars: 4 Votes
here is an image of what i had done. but like i stated it locked up the program having all those openings in 3 walls. it looked great. when i rotated around the building you could see the cooling towers through the wall.
Thu, Oct 30, 2014 at 2:43:14 PM | perforated brick screen wall
Don't do multiple openings.   Do as I showed, one void (in-place family) sketch on each wall face.
Thu, Oct 30, 2014 at 2:49:26 PM | perforated brick screen wall
vinnygolfer
4.5 Stars: 4 Votes
i'll try it either tonight, or in the morning. i have a presentation on this project in the afternoon tomorrow.
Perforated metal screen?
Fri, Nov 12, 2010 at 9:21:25 AM
brick screen wall
Sun, Nov 13, 2011 at 5:19:09 AM
Pattern brick wall
Thu, Nov 17, 2011 at 7:15:35 PM
Brick Jaali/Screen
Mon, Aug 26, 2013 at 8:02:39 AM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:23 PM
Page generation time: 1.7756
