59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> parameter problem
hi. i am trying to create a rebar detail component family. i've got it working to a point when i try and change the spacings (seems to semi work in project but not in the family). what i'd like is a reporting dimension that drives the amount of bars and keeps the spacings in around the OC (off centre) but it throws up the not hosted error message. probalby doing this all wrong but any help appreciated cheers
Are you aware that Revit has built in Rebar detail components?
ye they're not great tho. i'v realised that i cant have a reporting dimension that can be entered into a formula so i made do with "Length / Spacings + 1" number for bars and it seems to work ok. i've attached rfa file
Parameter names with dashes - problem with formula |
Tue, Aug 31, 2010 at 10:28:39 AM
Parameter problem |
Thu, Oct 22, 2009 at 10:14:18 AM
3D Swing parameter!! Help!! |
Sat, May 11, 2013 at 7:03:34 AM
Creating a wall tag with a volume parameter |
Sun, Jun 23, 2013 at 3:56:03 PM
Loadable Family Parameter Problem |
Mon, Jan 16, 2006 at 5:49:28 PM
Members: | 2000453 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
