60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Dimensioning with keynotes
hi. i am working on a detailing sheet with keynote references to the lengths of rebar etc. is it possible to either create or change the dimension text to a keynote tag? or if anyone knows of a workaround
also looking for a line based (side) metric UB detail component family if anyone has one would be great!
thanks
There are no variables in keynotes. Change the keynote and it changes everywhere it is used. So obviously it is not goor for dimensions.
You could have a tag that reads a length parameter .... must be shared parameter.
Edited on: Thu, Oct 2, 2014 at 11:32:13 AM
thanks for the reply i found a workaround to right click in the text over-ride and select US that gets rid of the dimension then just have a keynote with no leader seems to work so far
Keynotes |
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes |
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend? |
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing |
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management |
Mon, May 11, 2009 at 7:01:29 AM
Members: | 2000453 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
