62 Users Online (61 Members):
Forums >> Workflow & Implementation >> Worksets >> How to do Cable Tray with Real Material Color (Not just filter color)
I am creating a MEP walkthrough showing the as built cable trays, elec equipment, mechanical eqpt, pipings, ducts, etc. I want it to show in realistic mode without the edges (if possible rendered walkthrough mode). I already have assigned the filter for a cable tray network that is in actual, red in color. In Shaded 3d view, the color shows but in realistic mode, it doesn't! I can assign material in the Object styles dialogue but it assigns the material to all of the cable tray. I only need certain cable trays to be in color red.
I thought of editing the family and giving them Material parameters but I can only edit the fittings and not the Cable tray run! I also tried the Paint tool to no avail.
I downloaded the Hoffman cable trays from autodesk to solve this problem temporarily but I really want to know how to add materials to cable trays. So please shed me some light if you know.
Thank you so much!
J
Archidea |
Instead of assigning the material, try painting it.
I tried to paint it. It shows in the Coarse/Medium Detail but not in Fine Detail.
Archidea |
Hi Archjahz,
I have the same needs. please let me know if you have any solution. tks
Cable tray tee |
Tue, Nov 1, 2016 at 7:29:06 AM
Cable Tray Clearance |
Mon, Mar 24, 2014 at 10:44:48 AM
Cable Tray- Revit MEP 2013 |
Fri, Oct 5, 2012 at 8:29:45 AM
Revit 2015 - Ladder Cable Tray |
Mon, Feb 29, 2016 at 5:05:14 PM
Cable Tray |
Fri, May 9, 2008 at 7:28:19 AM
Members: | 2000332 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
