149 Users Online (148 Members):
Forums >> Revit Building >> Technical Support >> wall opening. Can't change dimension segment to this value
what are the solutions when revit gives you this repsonse.
making a wall opening near a perpindicular junction between two walls in revit 2015. i want it to be 738 opening but it sanps to 828 and wont let me change the dimension. i have tried disallowing and allowing wall joins but didn't work.
see attached print screen
another example of where this problem has occurred in my drawing
set up a camera view and it looks correct in 3d. so not too worried about it now...however it is misleading on plan view
I NEVER use wall opening tool. I think this tool never works right and is hard to use. I have a door family that is just the opening and is set to not schedule.
Hi WWHub, I have the same problem with the wall opening. Your solution is intillegent. Is it possible to share such door opening family?
Thanks
Sherazy
Sorry, I don't have that family here but it is so easy to make so you should do it. Just copy a standard door family with a new name and remove the door leaf and swing.
Yes this is what I did. Thanks WWHub.
1. Try: turn on the "show constraints" button and check if the opening constrains itself to the center of the perp wall.
2. Try to make the opening with "snap off"
3. Try making a reference plane (plan view) aligned with the face of the wall before doing the opening so the opening will snap to it.
4. If those dont work, use "in place (void) component" to substract it from the wall. (must be "generic model" or "wall" cathegory)
"can't change dimension segment to this value" error 2013 pipes |
Thu, Oct 18, 2012 at 7:56:04 AM
Hidden dimension segment |
Mon, May 3, 2010 at 9:06:52 AM
Placing an opening through a wall 'island' |
Wed, Jun 5, 2013 at 4:35:42 PM
Wall opening family in slanted wall |
Thu, Sep 6, 2012 at 2:50:57 PM
dimension strings |
Thu, Jan 12, 2006 at 7:42:11 AM
Members: | 1999122 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
