39 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Managing Pinned Files for a Team
29 Posts No Rating |
Hello, asking here because I am stumped. Revit Architecture 2013
I want to manage the pinned recent files for my team. While education on how to use these pins is great for the team. I want to set the top 5 to be certain files.
I do not know how to control the pin setting. I would assume it was in the USER Revit.INI file, but it is not. It must be an application setting somewhere and I have combed through the registry settings as well with no luck.
Has anyone came across these settings before? Where does revit remember that these items are pinned?
Thank-you,
Edited on: Tue, Aug 5, 2014 at 9:47:48 PM
I don't see any way to do what you want. This is under control of the user and is updated continually.
Apparently these settings are stored in the UIstate.dat file %appdata%\Autodesk\Revit\Autodesk Revit 2013
Does anyone know how to edit these settings or view this .dat file which will allow me to determine if I should set 1 and then xCopy it for my users?
Thanks!
Pinned walls in 2014 can't UnPIN Walls |
Wed, Oct 15, 2014 at 3:33:17 PM
Managing linked autocad files |
Thu, Dec 3, 2009 at 9:19:42 AM
Deleting local files and copying files from central |
Fri, May 23, 2008 at 11:28:55 AM
Make imported image NON-SELECTABLE (not just pinned) |
Fri, Sep 25, 2015 at 7:34:24 AM
Managing big linked files and exporting to 3ds max |
Tue, May 11, 2010 at 8:06:15 PM
Members: | 2005627 | Objects: | 22910 | Forum Posts: | 152188 | Job Listings: | 3 |
