Forums >> Revit Structure >> Technical Support >> PLEASE HELP! Revit + Sketchup intol Artlantis
5 Posts No Rating |
I have a uni assignent due and need this to work
I have a Revit model which has a sketchup model linked/imported as the context. So i export my revit file as an artlantis file using the artlantis plugin. Then i open it up in artlantis and only 1 building from the sketchup model is showing the rest isnt. (my revit model is showing up fine)
I dont know if anyone knows of a solution, i know its a specific question.
Artlantis is a rendering program which i have used before to import revit models into. The linked sketchup model is screwing things up.
I have tried to import the sketchup model into the revit model instead of linking it, but still no difference.
Is there a way of making the sketchup model part of the revit model somehow... maybe a layer or something?
2 Posts No Rating |
Did you try maybe binding the link in revit? This adds the linked file to the revit model- it can severely impact performance and model size though, so it may make it harder to work with in Artlantis.
(select the link and there should be an option to bind the link in the Modify panel)
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop? |
47 Posts No Rating |
You could also try inserting the sketchup model into a Revit family first and then inserting that family into the Revit file.
Edited on: Thu, Jun 5, 2014 at 3:49:31 PM
5 Posts No Rating |
By binding the link to revit do you mean go to manage links and selecting them and clicking import ? I've tried saving the sketchup model as a family then tried opening it in artlantis but no luck.
2 Posts No Rating |
I think there's some terminology confusion here. Are you linking or importing the SU file into Revit? Importing makes the file an editable part of the revit model, bringing in lineweights, line styles, layers, etc. You may need to be importing the file so that Artlantis will read it.
As far as you saying you tried opening the family through Artlantis, I believe Johnzo142 meant for you to insert the family into Revit first and then open the entire model through Artlantis. It doesn't sound like you've tried that.
Bind link only works for 2 Revit files, I did not realize that it wouldn't work for linking CAD- but that makes sense.
5 Posts No Rating |
Thanks for the reply, but i have already tried making the sketchup model a family and then importing the family into my revit file and then into artlantis. Likewise i have also tried importing and linking the sketchup model into my revit file and still no luck.
Cant think of anything else, guess it cant happen. Ive tried sketchup model on its own and revit on its own they both work... zzz
2 Posts No Rating |
Again, I think there's terminology mix-ups. You imported the family into the revit model? Why didn't you load it and place it?
5 Posts No Rating |
The sketchup model has too many faces and edges to be made into a massing then loaded into the revit file, i will try with a 3d warehouse component i have imported into my revit from sketchup, will get back to you in a sec
5 Posts No Rating |
FML IT WORKED! now how would i go about importing the sketchup model. Will i have to break it up into a number of mass families?
2 Posts No Rating |
Breaking it down into multiple pieces may make it easier to deal with in the long run anyways- the extra effort might be worth it.
There's also options within SU to purge and I believe theres also extensions to minimize extra faces and points.
(Window- Model Info- Statistics- Purge Unused)
Sketchup models can be placed directly into families where if a cuttable family, then the sketchup cuts.
Sketchup can also be directly imported into Revit.
5 Posts No Rating |
I will give it a go. its a context model so might have to cut parts of it off... im not too familiar with sketchup, can i create a place and trim everything outside the plane?
Thankyou so much for your help. appreciate it so much
5 Posts No Rating |
So this is what ive tried, the cafe which i created as an in-place mass, worked in artlantis. The large sketchup model which i couldnt create as an in-place mass because of its size, i made it by created a new generic model and loading it into the revit file. The sketchup model failed to show up in artlantis. so basically means i have to find a way to get the sketchup model to be loaded into my revit model by using the in-place mass....why is this so hard.
5 Posts No Rating |
For future reference in anyone ever has the same problem, unlikely because i dont know too many people who use artlantis.
The best way to go about it is open your revit model in artlantis, make the sketchup model an artlantis object (import skp file in artlantis, tweak it, set the origin, then export as atlo which is artlantis object). Save it into the artlantis library, restart artlantis and it will appear in the object list where you saved it. then just place it as you would with any other object. You cant edit materials though i dont think which dsnt really matter for me. fk yes!
