62 Users Online (61 Members):
Forums >> General Discussion >> Revit Project Management >> Rotating Family Text
Hello Reviters! I'm trying to build a general annotation tag family at the moment, which consists of an arrow linework and a text box. The text is placed on-center of the arrow, and I want the text to rotating along with the arrow when I rotate it within a project. However, for some odd reason, whenever the text is oriented in an angle that isn't within a multiple of 90 degrees, the text box shifts down in relations to the arrow itself. *See attached picture.
The text itself is already set to vertically align to middle, and I have tried setting the text into a group, so that I can change the center of rotation, but the text continues to rotate along a center that is slightly lower that where the center of the text should be. Has anyone ran across this issue? Thanks for your help!
Also, please excuse my post if it is posted in the wrong section of the forums. First time poster here!
Unfortunate, isn't it? Read post #27
http://www.revitforum.org/architecture-general-revit-questions/13590-standard-text-heights-3.html
Did you try a vertical align, middle format on that text?
I can't find a vertical align?
This is an annotation.
Thanks, WWHub.
For others searching, this doesn't work for text notes.
Rotating Symbol geometry without rotating leabel |
Wed, May 6, 2009 at 8:33:58 AM
Rotating text/label within annotation symbol |
Mon, Oct 26, 2015 at 7:19:59 AM
Annotation Symbol Text - Keep Vertical? |
Thu, Dec 15, 2011 at 3:23:42 PM
Photo symbol with non-rotating text |
Mon, Jul 14, 2014 at 11:36:09 AM
Rotating the text in dimensions |
Tue, Feb 17, 2009 at 12:18:16 PM
Members: | 2000472 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
