56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> first time using gross building area - whouldnt my shafts be deducted?
3 Posts No Rating |
hi, i'm just beginning a gross building analysis and I have many voids in my building- some are double-triple height occupant spaces some are mechanical shafts. In any case I thought there might be a trick to getting my gross calculation to excluide these from its summary - is there?
So many questions....
- Are you using Rooms?
- or are you using Areas - Area Plans?
- If using rooms, how did you create the holes?
- Did you add room seperation lines around the hole?
- On area plans, did you sketch them and add the holes?
Floor Areas and Shaft Areas |
Sun, Jul 27, 2008 at 10:39:38 AM
Rentable vs Gross area, gross area in practice |
Tue, Mar 13, 2012 at 11:15:27 AM
Gross volume of a building |
Wed, Jun 4, 2008 at 1:41:10 AM
Gross areas & Phasing |
Mon, Feb 23, 2015 at 9:14:01 AM
Gross Building Area Tag |
Tue, Feb 2, 2010 at 12:06:25 AM
Members: | 1999831 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
