80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Scaling Viewports
5 Posts No Rating |
Hi,
I have an A1 drawing sheet which I have just dropped my Ground Floor Plan into. The GF Plan was drawn at a scale of 1:100, but needs to be at a scale of 1:500 on the drawing sheet. When I change the viewport scale to 1:500, all the Grids and text stay at a scale of 1:100 (huge). I s there a way to bring the scale of he grids and text in line with the viewport scale?
Thanks
There really is no viewport in Revit. You change the scale of the actual view. If in your view you changed your scale from 1:100 to 1:500 the text will automatically change so you are doing something incorrect.
5 Posts No Rating |
Hi,
Any idea what I am doing wrong? I presume there is some setting I need to adjust?
Thanks
Grid bubbles and text are annotation and have no scale. They stay the same size on the sheet regardless of the scale of the view, so a 1/2" grid bubble will always print at 1/2".
Edit Visibility Graphics in multiple viewports? |
Mon, Nov 28, 2011 at 1:37:05 PM
Viewports orginizing on sheet |
Mon, Apr 18, 2016 at 10:45:14 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell |
Thu, May 23, 2013 at 2:28:19 PM
many viewports |
Mon, Aug 24, 2009 at 9:17:12 AM
Scaling Family or component- similar to scaling jpeg |
Mon, May 12, 2014 at 2:44:09 PM
Members: | 1998263 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
