89 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> Improper use of Boolean Expression message with my calculated value formula
24 Posts No Rating |
I'm trying to apply a formula to lumber studs. I have 2x4, 2x6, 2x10, and 2x12 and I want to be able give them a length for ordering based on what there actual cut size will be. For example I want to be able to label all 2x4's under 8' in length as "2x4x8 and all 2x4's over 8' in length as 2x4x10. I would like to be able to do this for all the different pieces of lumber I listed above. I was able to get the formula to work in excel but in Revit I get this error message "Improper Use of Boolean Expression". Here is the formula: IF(AND(Stud Type="2x4",Cut Length>,"2x4x10","2x4x8")
Formula should read: IF(AND(Stud Type="2x4",Cut Length>8,"2x4x10","2x4x8")
You're missing a closing paren after your AND expression.
Array formula (9.1) |
Mon, Sep 24, 2007 at 7:12:47 PM
String Values in Formulas |
Wed, Dec 4, 2013 at 10:38:12 PM
Bookend Room Schedule with Room Number |
Mon, Apr 18, 2016 at 10:54:09 AM
OCCUPANT LOAD FROM CALCULATED VALUE/IF STATEMENT |
Fri, Nov 21, 2008 at 11:42:14 AM
Calculated totals of formula in schedule |
Fri, Sep 11, 2020 at 7:14:07 AM
Members: | 1998267 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
