59 Users Online (58 Members):
Forums >> Revit Structure >> Tips & Tricks >> void in family is yellow
3 Posts No Rating |
When i try to create a void family the void gets created but show up as yellow and doesn't cut anything
I am making a void for a wall.
What am i doing wrong why wont the void work?
So you created a void family then loaded it into a project to cut a wall?
Once you created the void and inserted it into your project did you use the Cut Geometry tool? In the Family Category and PArameters did you check the box for Cut with Voids When Loaded?
Edited on: Thu, Jan 30, 2014 at 9:20:12 AM
A void family?
In order for a void family to work, it needs to be hosted. So your best process is to create it in a face based famil so that it works on any surface. In the family, pick the void and set it to cut the host.
Setting the family to ''cut the host'' is not enough, you need to, after having the family loaded, go to Modify tab/Geometry/Cut Geometry, select the host and the family so to have the desired cut effect.
fotio, there is no need to do what you say. If the family is built to cut the host in the family, it will cut the host automatically in the project.
when you insert the family, you have to set the parameter (in the properties dialog) that defines the depth of your void (or whatever parameter you assign to the void) BEFORE you pick the intended possition, because it starts in 0.00.
nested void family |
Wed, Jul 27, 2011 at 2:52:07 PM
Use Nested Void Family to Cut Host? |
Sat, May 28, 2011 at 10:39:48 AM
Void extrusion family visibility |
Fri, Apr 22, 2022 at 7:57:52 AM
Void Extrusion in window family problem |
Mon, May 18, 2015 at 3:55:23 PM
weird yellow render RAC2009 |
Tue, Jan 6, 2009 at 2:29:31 PM
Members: | 2000447 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
