115 Users Online (114 Members):
Forums >> Revit Building >> Technical Support >> need help with a formula for my calculated value
24 Posts No Rating |
I have a formula that has worked in excel but does not work in revit. I'm using a formula takes a value (length of stud) and determines if its greater or less than 4'. In one outcome if its greater I then divide by 10' and then round that number up. The other outcome less than 4' I just use the actual number. The formula works if I don't plug in the ROUNDUP portion. Take a look at my formula and see what I'm missing, thank you.
if(Cut Length > 4,ROUNDUP((Cut Length / 10),0), (Cut Length))
It looks like you aren't using the correct format for roundup (it should be "roundup(unitless number)"). I got this to work:
if(Cut Length > 4', (roundup(Cut Length / 10')) * 1', Cut Length)
That divides Cut Length by 10' to get a unitless number, rounds that up, then multiplies it by 1' to get it back to feet.
yeah that worked, thanks
Calculated totals of formula in schedule |
Fri, Sep 11, 2020 at 7:14:07 AM
Calculated Value |
Mon, Dec 13, 2010 at 4:46:58 PM
Schedules - Calculated Value does not have "Count" in the list of fields |
Thu, Oct 17, 2013 at 8:55:44 PM
Calculated value |
Fri, Aug 6, 2010 at 2:17:19 PM
Improper use of Boolean Expression message with my calculated value formula |
Thu, Jan 30, 2014 at 3:31:03 PM
Members: | 1998218 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
