Forums >> Revit Building >> Technical Support >> Equipment Roof Curbs
1 Posts No Rating |
I need a curb that will slope with the roof it sits on. I found a good roof curb.rfa on this site, but it seems it's only parameters are width, depth and height.
Any suggestions?
What parameter is missing? It sounds like you have what you want.
You don't tell us anything about the curb you found. A level based curb will fuction differently than a face based or roof based curb. The "always vertical" setting in the curb family will also affect how it functions.
1 Posts No Rating |
I forgot to mention that I am fairly inexperienced in Revit (tell me if you haven't heard that before on here!).
I attached the the file I downloaded from this site.
When I inserted the curb (by dragging it from the Families on Project Browser and dropping it on the roof) th ebase is not sloped to match the slope of the roof.
This is a level based curb.
I suggest you create your own family based on what you learn from this one. Use a face - based template - probably in the mechanical equipment category as this one was. Don't check the always vertical in the family category and parameters dropdown.
1 Posts No Rating |
Thank you for your reply. I am going to table this task for I bigger fish to fry at this moment. Our office is diving head first into Revit, and although we have taken a training, etc., there is no better way then to dice right in. So as much as I want to follow Revit to the tee and model everything, for the sake of time, we are going to have to forsake some of the details. My roof top units are set and located correctly in a 2D, but not 3D. What I am saying is, the HVAC roof plan "looks right", but if you look at any section or 3D view, they are floating. I will certainly jumpo back on this topic when I have the time.
Thanks for your help!
3 Posts No Rating |
It is been a long time passed i see the reply was on 2014, I just made a curb as WWHub said, It works nice with Parameters , I would like to publish and to share with others use and please WWhub review and comments will appriciated.
Hope it helps for others too.
0 Posts No Rating |
Discovering the Lil Bubba curbing machine for sale is like finding a gem in the landscaping world! Its advanced features make concrete curbing a breeze, and when coupled with equipment roof curbs, it's a powerhouse combo. Efficiency meets quality, ensuring every project exceeds expectations. If you're serious about your landscaping business, this duo is a must-have.
Edited on: Fri, Mar 1, 2024 at 1:14:38 PM
Driveway curbs |
Fri, Nov 18, 2005 at 4:47:10 PM
curbs? |
Tue, Dec 7, 2004 at 5:17:58 PM
Adding Roof Curbs for Mechanical Units |
Tue, Jan 22, 2008 at 11:46:05 AM
Site topo street curbs |
Mon, Jul 16, 2007 at 11:58:56 AM
CURBS AND SIDEWALKS! |
Fri, Feb 11, 2011 at 11:58:44 AM
Members: | 1998363 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
