145 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> autocad layers change color when imported into revit
Thu, Jan 16, 2014 at 2:44:41 PM | autocad layers change color when imported into revit
jkipfer1
I'm having an issue using 2014 suite of products.
I have our company logo in AutoCAD which has some colored solid hatch. When I import CAD and insert the dwg file into my title block family it is clear that the colors have changed. If I explode the dwg I can then see the layer colors in the object styles dialog and the layer colors have in fact changed. I have selected for the colors to be preserved in the Import Cad dialog box.
Does anyone know why the layer colors are changing?
Thanks,
Jason
Thu, Jan 16, 2014 at 2:53:25 PM | autocad layers change color when imported into revit
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
You really should not import CAD files, Revit doesn't always play nice with blocks and hatches.  Did you try Linking the file in instead?  Do you have all of the updates installed for 2014?
Thu, Jan 16, 2014 at 3:09:11 PM | autocad layers change color when imported into revit
TKennedy
4 Stars: 7 Votes
Check your Object Styles in the project. If you imported your .dwg with the wrong colors (or used invert instead of preserve), then deleted the .dwg and tried again, Revit will remember the original layer settings and will override them when you try to bring the .dwg in again.
Thu, Jan 16, 2014 at 8:14:06 PM | autocad layers change color when imported into revit
jkipfer1
Thanks for the responses.
I didn't think you could link a cad file into a title block family. Link Cad is greyed out.
Revit is up to date with patches.
I inserted the cad file using Preserve colors.
I only have a few dozen lines in my cad file. 2 layers.
Layer 1 is color 255-159-0 (RGB). Layer 2 is color 97-98-96.
Once inserted into Revit the colors are: Layer 1 255-127-0, and layer 2 is 101-101-101.
How is this possible?
Fri, Jan 17, 2014 at 7:19:08 AM | autocad layers change color when imported into revit
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
I'm sorry I missed that part of your post somehow that you were doing this in a family, you are correct there is no link CAD option in families.  The best way to deal with AutoCAD that you are converting into Revit is to basically redraw them.  You should do a save as in autocad and change all of the linetypes to 0, remove all of the hatches and make sure all of the blocks are exploded to get rid of any hidden unwanted linetypes that might come into revit, then import into a dummy Revit family and change all of the lines to your Revit standards before copying and pasting into your titleblock family to add all of your annotation.
Fri, Jan 17, 2014 at 8:14:23 AM | autocad layers change color when imported into revit
jkipfer1
I have tried this but run into the problem where Revit can't draw to the same small increments as AutoCAD. The famous
'lines too small on screen' and then Revit deletes these elements. So it's not possible for me to draw our logo in Revit, in a
titleblock family. Many firms use png's or jpeg's but no matter the resolution, these look fuzzy in pdf's.
Importing the logo as a cad drawing works fine. The logo is nice and crisp, I can scale it up and down but why would it change
the colors on me? I can't change the colors in the Revit file, because to do this I would need to explode the inserted Cad
dwg and that causes other issues.
I have the color close to what I want but it's not the same and would prefer the logo to look the same whatever program it
printed from (which is a chalenge).
Fri, Jan 17, 2014 at 8:52:40 AM | autocad layers change color when imported into revit
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
Would you be able to upload the CAD file to here so I can try to import it and see if I am getting the same problem?
Fri, Jan 17, 2014 at 9:14:41 AM | autocad layers change color when imported into revit
jkipfer1
That would be great, thank you.
Note that I would scale this logo up or down once in Revit depending on the size of the title block. For an 11x17 title block
the attached logo would be scaled down by about 1/2.  24x36 title block was no problem because, like you noted, I could
draw the linework in Revit. Smaller linework creates the 'too small on screen' issue.
I have also tried setting the layer color by HSL and pantone but the result in Revit is unexpected.
For example if I change the orange color from 255-159-0 to 255-160-0, it completely changes from a yellow/orange to a
deep brown in AutoCAD. Yet changing that middle (green) number from say 150 to 159 has no effect. Then all of a sudden
one number difference and the color completely changes.
I'm interested to see what happens with your test. I've made sure I have Revit up to date and my graphics driver also.
I haven't seen any similar postings though so maybe it's me...or maybe most firms use images or fonts for logos that
they can't draw in Revit.
Fri, Jan 17, 2014 at 10:07:59 AM | autocad layers change color when imported into revit
teafoe5
teafoe5 Avatar
4.5 Stars: 46 Votes
I'm not sure why it is not keeping the exact same colors from AutoCAD to Revit but they look VERY similar so I don't see the problem just using that.  Also when I explode it and go under visability graphics>object styles> I can change the color to be the same as the CAD colors.  If I were you I would change the scale to what you need in AutoCAD then bring it into Revit and use filled regions to create your logo.  I have attached a sample.  Your other option would be to try and create a higher quality jpeg.
Fri, Jan 17, 2014 at 10:33:32 AM | autocad layers change color when imported into revit
3.5 Stars: 391 Votes
I think that because we can zoom in very close, we become myopic in our concern about very tiny lines.  Yes, you can draw them in CAD but can you draw them by hand.  My rule of thumb is if I can't draw them by hand then they are not important.  Remember, in most cases today, our printing is all pixal/dot based.
Thu, Oct 9, 2014 at 9:57:23 AM | autocad layers change color when imported into revit
#11
pabgigo
What Revit does it to approximate the colors to the nearest 255 index color, but whit RGB values.
You must always use the By Layer color and then, in Revit Object Styles chage the color to the correct RGB.
Tue, Apr 25, 2017 at 4:11:26 AM | autocad layers change color when imported into revit
#12
PeteWCEC
Hi Guys,
I appreciate this is a 3 year old thread, however we have just had a similar issue.
Our blue logo imported green instead - not great.
We found the issue was due to the layer name of the imported CAD file.
Our layer was initially called "_LOGO".
It appears there was already a CAD import in the Revit project which had the layer name "_LOGO" already, which had it's own colour - green.
When we loaded in our cad logo, it changed to the blue to green.
To fix, simply rename your CAD layer to a unique name, eg "Architects_LOGO_2017" and re-import.
You may need to do this for all layers inserted.
Regards,
Pete
Fri, Oct 2, 2020 at 5:31:59 AM | autocad layers change color when imported into revit
#13
supertxull
Three years later, I find myself again with the same problem and I can't find the right solution.
I need to import my company logo in a title block and the color is similar (almost black) but not the correct blue. When this is an imported object in a title block family, I cannot modify its color.
Does anyone have any idea how I could solve it?
I attached an acad 2018 demo file to test. Correct colour is RGB 0,58,98 and the imported colour is RGB 0,28,38.
Thanks
Fri, Oct 2, 2020 at 8:00:25 AM | autocad layers change color when imported into revit
#14
hanbyjm
Why not just recreate the logo in Revit? If you know the color, you can create a new filled region with the color.
Sat, Oct 3, 2020 at 12:20:19 PM | autocad layers change color when imported into revit
#15
supertxull
Because the company logo is not just a circle...
Changes to AutoCAD layers when imported to Revit
Wed, Oct 29, 2008 at 10:35:39 AM
Linked AutoCAD layers change color
Mon, Feb 21, 2011 at 2:52:17 PM
[Frustration] How to separate Autocad layers in Revit?
Mon, Jun 25, 2012 at 11:31:55 AM
Layer Settings of imported Autocad drawings
Tue, Jan 18, 2011 at 8:14:16 PM
Importing AutoCAD Title Block Line Thickness Problem
Wed, Feb 20, 2013 at 1:40:15 PM
Page generation time: 3.7285
