Forums >> Revit Structure >> Technical Support >> Plan / Section question ???
8 Posts No Rating |
If I delete a plan view and I have section associated with that view is there a way that I can still keep the sections within that view ?
If you delete a plan view how would you keep the section in that view? The view is deleted so therefore there is no place for the section. If the section appears in another view it will not get deleted.
8 Posts No Rating |
right ok lets say im in a plan view and i want to do a stair drawing and i need a part of the plan where the stairs are, do i duplicate a copy of the plan view or do i do a callout of that area ?
Edited on: Mon, Jan 6, 2014 at 4:34:40 PM
Deleting a plan view will not delete any of the section views. You won't see the section callouts if they aren't visible in any other plans, but you can still find the section views in the project browser.
You can duplicate a plan, create a new plan or you can use a call-out - your choice. I prefer the callout so that the bubble directs the user to the view.
8 Posts No Rating |
I have a scenario; I’ve been told that it is good practice to not have too many levels (the only levels you should use is your main floor levels) So what is the best practice to do when you have a staircore and you have a stair half landing between floor levels.
Should I:
1. Duplicate a floor level and change its view depth ?
2. Add a new level for that half landing ?
I hope you understand what I mean
Cheers
We don't have a separate plan for the landing. It is shown in our floor plan for the main level. The mid landing is not a level and not a floor - it is part of the stair.
8 Posts No Rating |
but the half landing still needs supporting with steel so i will have to show it somewhere on a drawing. So im guessing the best practice is to duplicate a level and amend its view depth ?
In any plan view, you can add a PLAN REGION that allows you to control the VP in that area. Read your HELP on plan regions.
8 Posts No Rating |
Yea I've used plan regions a lot I'm just looking at what is the best practice. I used to use callouts for the half landings but I'm gonna start duplicating floor plans and with plan regions.
Thanx
Section tag missing on plan but section still exists |
Tue, Nov 22, 2016 at 2:58:15 PM
Cut Pattern in Plan vs Section |
Tue, Aug 25, 2009 at 8:47:59 AM
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:25 AM
Section Line in Extends Beyond Plan (2009) |
Sun, Sep 21, 2008 at 11:30:18 AM
plan detail callout in section |
Fri, Mar 29, 2013 at 12:48:11 PM
13
