66 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> How to make an aligned dimension?
0 Posts No Rating |
I want the dimension (1) to be parallel & aligned to my property line (2). I chose "Aligned Dimension" (DI) but it doesn't do what I want it to do. I've tried all the other relevant dimension options, none of them works... Can somebody help me here? I'm new to Revit so I really need you help.. Thank you so much
Archidea |
Check the Similar Threads posted below. You should find your answer there.
Dimension aligned |
Thu, Nov 17, 2011 at 9:49:27 AM
Aligned dimensions on non-orthogonal walls |
Sun, Jun 11, 2006 at 8:16:11 PM
Aligned dimensions |
Wed, Apr 12, 2006 at 3:22:31 PM
Using Aligned dimension to manipulate a square to perfect specifications???????? |
Mon, Sep 23, 2013 at 8:00:53 AM
Aligned dimensions for centering curtain wall door |
Fri, Dec 23, 2011 at 6:26:40 AM
Members: | 2000339 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
