36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> add beams conceptual mass
Mon, Oct 14, 2013 at 11:02:18 AM | add beams conceptual mass
s110950
When i try to add a beam by picking a line it places the beam on the ground, eventough 3d snapping is checked. I don't know why becease it worked on the other beams but not on this one. You can see it in the picture, what's going wrong?
Mon, Oct 14, 2013 at 11:06:25 AM | add beams conceptual mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your image doesn't really tell us much. are you sure your not picking a wrong line? What is a pipe beam?  Is this a custom family you created?
Mon, Oct 14, 2013 at 11:18:03 AM | add beams conceptual mass
s110950
It just doesn't create a beam on the line I'm picking like it did with the others already there. I downloaded this pipe beam from revit city, it says it's structural framing
Mon, Oct 14, 2013 at 11:21:42 AM | add beams conceptual mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure you are picking the correct line and not something on the floor?  When you hover over the line Revit will tell you what it is on the bottom left corner.
Tue, Oct 15, 2013 at 4:01:42 AM | add beams conceptual mass
s110950
I really am selecting my conceptual mass, like you can see in this picture. Still it will create it on the floor, I could upload the file if you think you know how to fix it?
Tue, Oct 15, 2013 at 7:52:39 AM | add beams conceptual mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Without doing it and I don't work with masses often, That looks pretty vertical, could you try using a column family instead of a beam just to see what happens?
how to make beams from a mass model, and how to add a floor to it
Sun, Oct 22, 2017 at 1:10:11 PM
conceptual mass problem
Fri, Jan 13, 2012 at 4:02:05 PM
conceptual mass -newbie to that
Mon, Feb 21, 2011 at 9:21:36 AM
Scaling Conceptual Mass
Mon, Oct 11, 2010 at 7:34:51 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
Page generation time: 0.9987
