64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Arc-based family
Sun, Sep 29, 2013 at 9:20:14 AM | Arc-based family
SoWhat
Hi there! I know there is a way to create line based families, but instead of a line is it possible to create them based on an arc? The thought came to me when I was fiddling around with some insulation detail component which is created by specifying only it's radius. And then it creates this circle of insulation. But it is a complere circle and it is not possible to split it, so what if I only want an arc of the insulation? If anyone has any tips and tricks on how to solve this, please throw them in. I've attached the family I have so you're welcome to try and tweak it.
Mon, Sep 30, 2013 at 10:33:59 PM | Arc-based family
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
I've made a family which based arch, with 3-points circle.
http://plevit1.blogspot.kr/2013/08/3-points-circle-3-points-arch.html
hope this helps.
want more?
You can get more tips at Enjoy Revit
Thu, Oct 10, 2013 at 2:50:40 AM | Arc-based family
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
I wrote about this issue at my blog.
http://plevit1.blogspot.kr/2013/10/curved-insulation.html
and don't miss the file attached there.
Enjoy. :-)
want more?
Fri, Oct 11, 2013 at 6:47:41 AM | Arc-based family
SoWhat
Thanks! And thanks for the tips on curtain walls from last weeks! Smile It was me again! Smile
Mon, Nov 28, 2016 at 1:02:55 AM | Arc-based family
benjaminabbott
Hi dingohot,
Great family! It's nearly 2017 and there's still no curved insulation option. I looked on your website link for the download but couldn't find it. Would you mind helping me locate it please?
Thanks
Parametric Arc Sweeps - How to Bypass the Concentric Arc????
Mon, Jan 14, 2013 at 9:00:27 PM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:38 PM
Divide arc by length
Fri, Sep 7, 2007 at 6:17:47 PM
Radial/ Polar Array.
Fri, Feb 1, 2008 at 2:19:22 PM
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:05 AM
Page generation time: 0.8506
