57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Revit freezes when I do a 'Save As'???? Need help urgently!
Whenever I am in a family or a project and want to do a Save As, once I click on the option it freezes and no dialog box appears. The program isn't truly frozen and will "unfreeze" once I hit escape. I've upated with service packs and nothing helps. Restarted the computer, still nothing.
Can anyone help???
Wierd... what version of Revit? Did you updated your Graphic card drivers ?
Are you saving from tiled views? << Don't do that!
I have Revit 2013.
No, whenever I try to save as from a simple family type it won't allow me the option either.
There are strange things that happen sometimes because of the operating system still limited by old rules. Try this - run CCleaner and let it clean up your temp files. Please let us know if that works.
I tried the CC Cleanup. It didn't work. :-(
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
'save as' reduces file size - a good method? |
Tue, Sep 23, 2014 at 7:36:45 AM
Revit Freezes |
Wed, Nov 23, 2005 at 6:09:57 PM
RPC's won't render in 3DS Max after importing from Revit |
Sat, Dec 17, 2005 at 9:10:50 AM
Archiving worksets |
Thu, Sep 1, 2005 at 1:14:55 PM
Members: | 2000399 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
