61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Revit 2013 Revit Families Prior to Revit 8.1
Wed, Jul 10, 2013 at 7:11:24 PM | Revit 2013 Revit Families Prior to Revit 8.1
RevitMaestro
I cannot seem to download and open alot of the stuff that is posted on this site, because I am using Revit 2013 maybe?  A message comes up,  "cannot open because it was saved in a version of Revit prior to 8.1.
Am I doing something wrong?  Is there a program that will open these files and upgrade them to a later version?
Thu, Jul 11, 2013 at 7:14:38 AM | Revit 2013 Revit Families Prior to Revit 8.1
3.5 Stars: 395 Votes
You can open any earlier version of Revit families or projects and they will upgrade/convert to the release you are in.
But ... you said prior to 8.1.  What objects are you trying to use.  Maybe something very - very early on our site has a problem and if so, we need to know what.
Thu, Jul 11, 2013 at 9:09:25 AM | Revit 2013 Revit Families Prior to Revit 8.1
RevitMaestro
I tried opening "exit sign symbol".  I tried both dragging, and also opening from within Revit.  This happens quite often.  Ive used other versions of Revit and never had this problem.  Last version I used was Revit 2011 and Revit 2012 full version.  I am now using Revit LT 2013.
Here is a screen shot of the objects i downloaded and the message when i tried to open:
Thu, Jul 11, 2013 at 10:01:45 AM | Revit 2013 Revit Families Prior to Revit 8.1
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Opens fine for me in 2013.  Maybe the LT version has restrictions.
http://www.revitcity.com/downloads.php?action=view&object_id=1122
Apparently this is a restriction in 2013 LT.  I read in a discussion that Autodesk was trying to fix this in a service pack.  Do you have the service packs installed?  If not do that and see if they have fixed the problem.
Edited on: Thu, Jul 11, 2013 at 10:03:44 AM
Revit Architecture 2013 Missing Families on Install
Sat, Oct 13, 2012 at 9:54:27 AM
Upgrading from revit 2012 to 2013
Tue, Apr 23, 2013 at 9:34:40 PM
Revit 2013 Deleting Hosted Families
Mon, Feb 11, 2013 at 12:05:45 PM
Revit Building Display Error - prior to crash
Fri, Apr 2, 2021 at 2:38:59 PM
Annotation at the family level prior to being imported to Projects
Fri, Jan 16, 2015 at 7:23:35 AM
Page generation time: 1.9480
