53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can't select Wall and Grid - Not Design Option fault
Thu, Jun 20, 2013 at 10:26:24 AM | Can't select Wall and Grid - Not Design Option fault
MEBDesign
Strange problem, I have two walls in my project which have become un-selectable. In the attached screenshot it shows one of the walls not highlighted. This was despite doing a drag and select over the area. Also strange is that I cannot select either of the grid lines that these two walls are on. From searching about the solutions seem to be to check if the walls are in other design options, which they are not. I can't select these walls in any views by dragging selecting, tabbing though objects etc.
Using Revit 2014
Any ideas on what's happened?
Thanks
Edited on: Thu, Jun 20, 2013 at 10:27:58 AM
Thu, Jun 20, 2013 at 10:30:13 AM | Can't select Wall and Grid - Not Design Option fault
MEBDesign
OK solved this seconds after posting ha! Walls had been pinned but the 'Select Pinned Objects' tool had been disabled!
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Annotations and fill patterns not automatically resizing when rescaling views
Tue, Feb 28, 2012 at 1:47:16 AM
2'x2' Diemsional Grid
Wed, Feb 5, 2014 at 2:10:47 PM
design option for same plan
Mon, Jan 23, 2006 at 1:09:30 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Page generation time: 3.2326
