43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Wall opening setback for door jamb
28 Posts No Rating |
I am trying to have wall opening setback for door jamb sweep. That way outer face of door jamb will be the door width, and the actually wall opening will be a couple of inch wider for the jamb. I read a lot about people talking about instance parameter or something, but I could not find a step-by-step instruction. I've also downloaded bunch of other doors that have such wall setback and studied the family types, but I failed to figure out myself (I just started teaching myself Revit.)
Could someone please help me?
"I read a lot about people talking about instance parameter or something"
Parameters are what make families in Revit special. You need to read up on what they are, what they do, how they work etc. Here is a good families guide to help you start.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Door position in depth of wall |
Thu, Dec 29, 2016 at 3:53:44 PM
how can I make an arc setback in a revit wall, not openings. |
Mon, Oct 25, 2010 at 1:26:48 AM
Wall opening (door) |
Tue, Mar 31, 2015 at 10:58:12 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing |
Mon, Jan 19, 2015 at 7:41:36 AM
Door Openings Clash Detection |
Thu, Aug 4, 2011 at 12:03:56 AM
Members: | 2000493 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
