68 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> Using Revit to Detail Complex Curved Geometry (Rhino/Inventor Unfold Command)
29 Posts No Rating |
I will be needing to detail this complex swept blend. See attached images. Basically, it is a tree feature in an interior space. Each arm is a different length, depth and arc. The difference between them should be the same, minus the length. I am looking for a technique similar to the Rhino or Inventor unfold command. I know Revit does not have this ability, sadly. I am looking at figuring out the standard deviation in depth and arc location per segment and using a note to cover it. I could do this in sections of 4 or 8 and then label / dimension the legs on plan.
Another option may be to draw a standard detail and then dimension it per each instance on a sheet. I might beable to get a few per sheet. (output A3 size)Does anyone have any other tricks to get this detailed to be built?
Revit 2013
Edited on: Wed, Apr 17, 2013 at 4:56:55 AM
I think doing them as individual sections is your only option. There is no way to "unfold" them. Only other thing I can think of is to tag each one individually and have a schedule or even a legend for the family.
Modeling Complex Floor Plates |
Fri, Oct 28, 2011 at 1:40:27 PM
Rhino imported as mass |
Tue, May 7, 2013 at 12:58:00 AM
Complex Curved Walls - please help |
Wed, Mar 25, 2009 at 5:26:10 PM
Complex Revit Drawings |
Wed, Feb 2, 2011 at 5:55:23 PM
complex curved roof structure |
Thu, Mar 12, 2009 at 1:11:49 PM
Members: | 1998263 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
