37 Users Online (34 Members):
Forums >> General Discussion >> Revit Project Management >> Different horizontal width mullions corner
4 Posts No Rating |
Hi Folks,
I have two different horizontal width mullions joining at a corner, (as you can see it the image sample) but I can get to make it right. Seems that is difficult when the width varies.
I could model an in place model for this corner, but seems there should be another way around to control how different with mullions join at a corner.
Seems to me that is the only solution you have given Revit... a mitered corner and all miters are 1/2 the angle.
Model in place is your answer.
4 Posts No Rating |
WWHub,
Thanks again Man!, well that is something autodesk could work on, to make editable mlion conditions, like they did for stairs...
Gracias!
Curtain wall mullions (specifically corners) need a serious overhaul. We need an API.
We don't miter these. We extend the CW to the edge of the other CW mullion and then we add a grid at the glass corner and don't have glass in that last sliver panel. Square mullion by-pas corner, not mitered. Renders and shows correctly in all views.
cleanup horizontal mullion at corner mullions, again.... |
Wed, Jan 8, 2014 at 11:14:49 AM
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
connecting horizontal mullions around a corner mullion |
Thu, Nov 17, 2011 at 12:38:25 PM
Corner Mullions |
Fri, Dec 6, 2013 at 11:05:58 AM
Different sized Mullions |
Wed, Aug 7, 2019 at 5:48:08 AM
Members: | 2070176 | Objects: | 23097 | Forum Posts: | 152262 | Job Listings: | 3 |
