51 Users Online (50 Members):
Forums >> Revit Structure >> Tips & Tricks >> RAIL - WALL BRACKET
Hi,
I am not able to make the wall bracket touch the handrail, what am i doing wrong. pls. see attached.
i have drawn this handrail after creating stair. no matter how much i try i am not able to make the wall bracket touch the handrail correctly, WHERE ARE THESE SETTINGS TO ADJUST ?
Revit Architecture 2012
Thx.
W
The bracket family is done as a balluster. Look at your settings for that balluster. Without opening mine, I believe the variable that needs to be changed is offset.
I modified an exsiting baluster to make a customize bracket so it can be added to my handrail. I load it to my project but when I tried to edit my handrail adn change the "Type" to the one I created it doesn't show up. I am not sure what is the right way to do this. please help!
I have the same "baluster not showing up" problem but with the one that do show up, what you have to do is set the host in the top rail with a negative offset equal to the heigth of the baluster you created.
rail on ramp with constant height bracket? |
Fri, Jan 8, 2010 at 1:52:17 PM
2013 railings: top rail editing | wall hosting |
Sun, Jul 28, 2013 at 9:32:46 PM
rail termination |
Tue, Apr 8, 2014 at 10:18:59 AM
Set baluster on Bottom Rail |
Thu, Mar 29, 2012 at 8:59:47 AM
Handrail Bracket to rotate with slope of railing |
Fri, Jul 6, 2012 at 10:16:39 AM
Members: | 2000447 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
