67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Topo Thickness Issue in 3D view
3 Posts No Rating |
Hello, my first post....
I have a problem that I have spent many hours trying to solve but with no success. I am on Revit 2011 Arch.
1. When I create a Toposurface it does not show the depth in the 3D model.
- I have adjust the poche value accrodingly and it shows/displays fine in elevation view.
- I have checked that nothing obvious is hidden. All graphic settings seem OK.
- Section boxing the 3D view work fine but still no depth in Topo, its like a thin layer.
Here's some images to show you what I am getting and what I would like to do....
Any help would be great, Thanks.
Make sure your topography extends beyond what you want to show, then create a section box to the limits of what you want and turn that on in your 3d view.
3 Posts No Rating |
Ok thanks, tried to follow what you said but nope nothing works.
Revit 2011 (Home) Revit 2013 (Work) AutoCAD (>2002) |
Like WWhub said...
3 Posts No Rating |
Well thanks again for your replies.
After trying a few more times with your advise, I have figured it out now. :-)
Its basically I mixture of crop view, poche and section box settings.
Cheers
0 Posts No Rating |
Nice Post
Topo Cut Line thickness |
Tue, Feb 14, 2012 at 10:49:24 AM
Adding thickness to topo surface??? |
Fri, May 12, 2023 at 10:49:55 AM
Changing wall thickness issue |
Thu, Oct 12, 2006 at 11:07:14 AM
topo depth |
Wed, Nov 7, 2012 at 2:17:31 PM
14
Topo & Subregion issue |
Mon, Sep 1, 2014 at 6:27:00 PM
Members: | 1998349 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
