150 Users Online (148 Members):
Forums >> Revit Building >> Tips & Tricks >> HIDING FLOOR EDGES ON WALLS
1 Posts No Rating |
Hello,
I am trying to find a solution to the floor edges that are showing through the walls in my Revit house. I attached a picture. Even when I render, for example, the white floors show through the brown stone. HELP PLEASE!
Thanks
Build the model like you would build the house. If the floor doesn't go to the ouside face of the wall then edit the floor sketch accordingly.
Try to join the wall and floor together.
jmagruder
Just joining will not work here. Read "
Applying a Function to a Layer of a Compound Structure" in your HELP
How did you end handling this?
Hiding the edges of a topographic surface |
Mon, Nov 3, 2008 at 10:44:15 AM
Hiding edges of extrusion in my plant component |
Thu, Oct 18, 2018 at 12:15:31 AM
Hiding walls |
Sun, Apr 17, 2005 at 3:55:24 AM
Cutting floor slab edges out of pads |
Mon, Oct 25, 2004 at 10:43:54 PM
Demolished walls hiding proposed stuff |
Tue, Sep 20, 2016 at 5:54:34 PM
Members: | 1998986 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
