41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Rotaring Car in Elevation/Section
Tue, Oct 30, 2012 at 3:36:28 AM | Rotating Car in Elevation/Section
mlagunzad
Hi There, anyone can rotate a car in section/elevation? I've tried to edit the family and uncheck 'always vertical' but still not working.  I am trying to put it on a ramp, it works on a floor and pick host but not on a ramp. Thanks in advance!
Edited on: Tue, Oct 30, 2012 at 4:25:46 AM
Edited on: Tue, Oct 30, 2012 at 4:54:33 AM
Tue, Oct 30, 2012 at 7:45:07 AM | Rotaring Car in Elevation/Section
3.5 Stars: 395 Votes
Not all families are built equally.  Obviously if this is a floor hosted family, then you will probably need a floor instead of a ramp.
Most cars are just imports from sketchup into a family.  If you can't find a family that works, you could build your own.  If the family you have is a CAD import, you could add a rotating reference line in the family and align-lock the import to that <<I Think.
Tue, Oct 30, 2012 at 1:47:03 PM | Rotaring Car in Elevation/Section
Thread Post Kudo! #3
4 Stars: 201 Votes
Edit that (CAR) family, goto "Family category and parameters", turn ON "Work-plane Based", load into your project, select the car and on Ribbon you will see "Pick New", select "Face" and now in a 3D view select the face of that RAMP, OR pick "Edit Work Plane" and select "Pick a new host" and select the face of the ramp.
Tue, Oct 30, 2012 at 10:18:23 PM | Rotaring Car in Elevation/Section
mlagunzad
Okay, Thanks Guys..Thanks Typhoon!!! . It Helped me a lot! Cheers!!! (: Thanks WWHub!
Fri, Jul 20, 2018 at 7:36:58 AM | Typhoon
seychellian
Quoting Typhoon from 2012-10-30 13:47:03
Hi is there a way to rotate it without hosting it? I ask because my topography is in a revit link and it wont let me host the vehicle onto a link.
Car 3D Model
Fri, Aug 5, 2016 at 9:30:37 AM
car and tree families for plan, section and elevation drawings
Mon, Apr 21, 2014 at 9:34:09 AM
How do you change car colors (properties)?
Wed, Mar 9, 2005 at 5:21:53 PM
I need a small Hybrid car model for a rendering
Wed, Jun 1, 2011 at 8:18:12 AM
Garage Wall in Options
Wed, Aug 10, 2011 at 4:39:22 PM
Page generation time: 0.6111
