63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Floor drain slopes adding lines to the slope when modifying sub elements
5 Posts No Rating |
using Revit 2013. I am trying to model the garage floor with drains and appropriate floor slopes. When modifying the sub elements to get the elevations accurate the program automatically assumes all edges of the area are at the same level. I want to show for slope lines, not lines to all corners. How can I make the floor slope based only on the outside edge of the floor?
A little confused... You can change each line / edge elevation or each point elevation, if this is what you want...
5 Posts No Rating |
The issue is that i Want to control what lines show an edge sloping towards the drain. If I specify heights of specific points and lines, it draws in mulitple lines where is believes a new slope would be.
Floor slab slope to drain |
Wed, Mar 11, 2009 at 11:04:06 AM
Dual Sloped Floor without Modifying Sub Elements |
Thu, May 5, 2016 at 8:08:50 AM
roof issue (even roof valley slopes with uncentered drain locations) |
Wed, Mar 14, 2012 at 12:25:14 PM
Floor Drain |
Wed, Jan 26, 2011 at 11:41:11 AM
Floor Drain Primer |
Mon, Sep 14, 2009 at 9:49:12 PM
Members: | 1999855 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
