53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how to convert a template to project file in 2012
Fri, Sep 7, 2012 at 8:38:31 PM | how to convert a template to project file in 2012
vinitnikumbharchitec
Hi
I made a template file and after working on it saved it. I continued thinking that the template file is a project file . Now I want to save this file as a project file to enable worksharing. I tried doing a save as but the project file tab is greyed out. I also tried closing the file and changing the file extension to .rvt but still it dosent help as i cannot do a save as of a project file and enable worksharing.
Sat, Sep 8, 2012 at 12:05:10 PM | how to convert a template to project file in 2012
revitape
revitape Avatar
4.5 Stars: 9 Votes
You were correct in changing the file extension. I am not sure why it is not working for you. Try changing the file name as well when you change the extension to .rvt
When I did this it worked fine and I was also able to do a save as and enable worksharing.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Sun, Sep 9, 2012 at 8:43:32 AM | how to convert a template to project file in 2012
coreed
coreed Avatar
4 Stars: 16 Votes
Since you saved it as a template file, leave it as .rte and sart a new project and select it as the template to start the project. Now you will have a new un-named project file with the information contained the template file that you were using a a project file. Now you can save and named the file. I see this so often.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Sep 9, 2012 at 10:01:02 AM | how to convert a template to project file in 2012
revitape
revitape Avatar
4.5 Stars: 9 Votes
His problem was that he started working in the template file thinking it was a project file.
Sun, Sep 9, 2012 at 11:16:04 AM | revitape
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting revitape from 2012-09-09 10:01:02
Correct. Leave it as a template file and start a new project using that file as the template file to start the project.  All the info will be there because he created it in a template file. Once he you saves it as a project file, he can delete the template file mistake. As I said, I see this so often.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Sep 9, 2012 at 11:57:15 AM | how to convert a template to project file in 2012
revitape
revitape Avatar
4.5 Stars: 9 Votes
Ah I see what you are saying now.
Wed, Jul 31, 2013 at 4:07:46 AM | how to convert a template to project file in 2012
wernervdpoll
im a new user and i have made the same mistake. now i tryed to create a new project and select the template. the project get created but the file is emty. no model, floors, wall, roof attributes? any other way maby? many thanks.
Wed, Jul 31, 2013 at 7:39:47 AM | how to convert a template to project file in 2012
3.5 Stars: 391 Votes
Find the file you think you created as a template.  Open it and simply do a save as .... and DON'T choose template!
Thu, Aug 1, 2013 at 2:17:24 AM | how to convert a template to project file in 2012
wernervdpoll
thank you, i Have tryed that, attached image is what i see. i go save as. then it gives ne four options to save in, but projects & families are greyd out. doesnt seem to work for me.
thank you for the post though!
Thu, Aug 1, 2013 at 6:36:26 AM | how to convert a template to project file in 2012
Something is corrupted.
Your not crossing the line between student and licensed versions, are you?
Fri, Aug 2, 2013 at 2:58:22 AM | how to convert a template to project file in 2012
wernervdpoll
hi wwhub, thanks for the help. been running the trail to see if its worth the lurning curve, but im going to be honnest, i had a nightmare getting revit to work on my machine, think what i need to do is whipe it and do a fresh install as theres a couple of wierd things happening, other than that the program is really amazing. think i am being converted.
Convert central file to another template, Revit 2016
Tue, Aug 2, 2016 at 6:11:06 PM
Save an existing project file as a template file
Mon, Oct 26, 2009 at 1:11:47 PM
Project Template
Thu, Oct 28, 2010 at 10:50:06 AM
Autocad Template file to title block
Mon, Jan 16, 2006 at 12:02:50 AM
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
Page generation time: 2.3595
