49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> transferring room names form one phase to thenext
Thu, Sep 6, 2012 at 12:35:22 PM | transferring room names form one phase to thenext
michB
Revit 2013.
How do I transfer room names from one phase to the next?
Thu, Sep 6, 2012 at 12:59:03 PM | transferring room names form one phase to thenext
3.5 Stars: 391 Votes
If the rooms are still there, the names are.  Just tag the rooms.
Thu, Sep 6, 2012 at 2:35:32 PM | transferring room names form one phase to thenext
quinn
Rooms do not transfer through phases.  You will need to add a new room in the new phase.
Thu, Sep 6, 2012 at 3:18:41 PM | transferring room names form one phase to thenext
mhans
3 Stars: 10 Votes
Are you talking about 'Design Options' or Phasing?
Motto: "No Post left behind"
Thu, Sep 12, 2013 at 12:28:15 PM | transferring room names form one phase to thenext
michB
SAME PROBLEM A YEAR LATER Smile
REVIT 2014-Room names and phases.  I still need to understand how to transfer room names from a previous phase.  The same with color fill schemes-How can I transfer it from the previous phase to the recently created phase as most of the information still applies.
Thu, Sep 12, 2013 at 12:42:53 PM | transferring room names form one phase to thenext
mhans
3 Stars: 10 Votes
This could have been dealt with. Obviously, Autodesk is not reading our woes. I can't help you right now but soon will. BC.
Thu, Sep 12, 2013 at 1:03:57 PM | transferring room names form one phase to thenext
Ranger57
Copy the rooms and tags from one phase and paste aligned to the next phase, each phase has it's own rooms ie two sets.
Thu, Sep 12, 2013 at 1:07:48 PM | transferring room names form one phase to thenext
michB
any options for transferring color schemes from one phase to the next?
Thu, Sep 12, 2013 at 1:12:55 PM | transferring room names form one phase to thenext
oneworld279
I agree with Ranger57, just copy the rooms and paste 'Aligned to Current View'.
In Solidarity
Thu, Sep 12, 2013 at 1:20:16 PM | transferring room names form one phase to thenext
michB
Some elements were not copied.Can't Copy to Clipboard because of relationships between Elements
is the asnwer I got-great thought though.
Thu, Sep 12, 2013 at 2:32:14 PM | transferring room names form one phase to thenext
#11
You need to make sure of your selection set before you copy.
Display Phase I & Phase II Room Names Together
Fri, Jan 11, 2013 at 2:53:39 PM
Room names not showing up on different phases
Wed, Apr 25, 2012 at 10:47:08 AM
Room Names/Legend
Thu, Feb 17, 2005 at 6:00:22 PM
Abbreviating Room Tag Names vs. Schedule
Thu, Sep 1, 2011 at 2:05:14 PM
Room names not showing up when linking Revit files
Sat, Sep 25, 2010 at 1:35:30 PM
Page generation time: 0.4355
