32 Users Online (31 Members):
Forums >> Revit Building >> Tips & Tricks >> Hide joint lines in 3D and elevations
How to hide those joint lines in 3D and elevations?
Thanks!
Did you do those stairs in one sketch with a landing? If you had, I don't think you get those stair stringer lines. Same with the handrail.
Get your desired view and use linework, use invisible.
Motto: "No Post left behind" |
Thanks Mhans! Does any "global" way to do it? I had go to each view, sections, elevations and 3D, to hide those lines.
I check the Object Style but found none. I guess Revit has not thought of it. Here's your workaround that can save you time. For 3d, clean up one 3D view of all those undesireables and duplicate it with detailing and adjust to the view you prefer. For Elevation, go to Visibility/Graphic overrides and select 'medium or coarse' detail level on railing or stair.
How do you hide the joint lines between different wall types? |
Fri, Nov 16, 2007 at 8:16:34 AM
How do you hide different material joint lines? |
Thu, Sep 15, 2011 at 6:53:41 AM
Creating joint lines!!?? |
Mon, Mar 27, 2006 at 10:59:33 AM
Hide infilling lines |
Mon, Aug 22, 2011 at 2:51:33 AM
Elevations - Hide at Scales Courser Than |
Mon, Mar 20, 2017 at 3:11:41 PM
Members: | 2000467 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
