47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Ramp Slopes
Thu, Jun 14, 2012 at 11:43:14 AM | Ramp Slopes
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I just found a simple solution to a problem thats been a pain in my side for years. if you want to annotate a slope arrow onto a ramp simply set a slope arrow on an object on your project, it doesn't matter what it is. The copy that slope arrow onto your ramp, as you drag the arrow over the ramp it will highlight the run of the ramp and you can select the "nearest" point. Somehow that picks up the slope...
Mon, Jun 18, 2012 at 11:29:47 AM | Ramp Slopes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Nice tip, thanks!
Thu, Jun 4, 2015 at 3:19:33 PM | Ramp Slopes
3.5 Stars: 395 Votes
I just saw this.... good tip except it doesn't work if you first place the slope arrown on a flat surface.   The NO SLOPE will not change so I just created a temporary rectangle floor with a slope arrow and placed my annotation slope arrown on that and dragged it onto my ramp.   I sloped the temp floor the wrong way but no problem - the slope arrow reversed.
You can do the same thing with spot elevations.
ramps with multi slopes
Thu, Apr 23, 2009 at 12:53:24 PM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Wall attached to Ramp
Fri, Apr 19, 2013 at 1:19:57 AM
Sloped curved ramp...
Sat, Oct 12, 2013 at 8:42:30 PM
12
slab with 2 slopes
Wed, Apr 15, 2015 at 9:22:17 AM
Page generation time: 0.2588
