60 Users Online (58 Members):
Forums >> Revit Structure >> Tips & Tricks >> Automatic View Title Extension Length
32 Posts No Rating |
It was always really annoying to me that the extension line would default to the width of the view. In some of the instances, the crop region or some other hidden element make the view much bigger than the section or view itself. (I have a noteblock that has 2 different sizes and is notorious for this).
I finally figured out an easy workaround (I'm wondering if everyone else already figured this out :-/ ). Instead of using the extension line in the project, I make the label for the View Title underlined so that it's always just the same length as the text. You don't have much control (any?) over the thickness of the line but it does make the View Titles all look the same without going through the extra step of aligning them where you want them.
Anyway, hopefully someone finds this helpful.
Thanks,
Kris Runung
Project Manager/Engineer
McClone Construction Co
Wheat Ridge, CO 80033 |
Nice little work around.
Now can you help us figure out how to make a window get justified by the Head instead of the Sill when changing the window size : )
Sorry dgcad. I work in RST. I'm fairly useless in RAC :-/
Kris Runung
3 Posts No Rating |
I was looking to try this out - how do we add the underline? I can't get into edit the type...
The view title, to be used, is a property of the view itself and it can be edited by right clicking it in the project browser under Anootation Symbols.
THANK YOU SO MUCH!
I WAS FRUSTRATED BIG TIME ABOUT THAT EXTENSION LINE LENGTH!!!
View title extension line grips trouble |
Wed, Oct 9, 2013 at 2:04:27 PM
View Title Extension line |
Mon, Apr 23, 2007 at 6:38:22 PM
Automatic extension gate |
Wed, Dec 26, 2012 at 11:56:03 AM
Deleting View Title Extension Line. |
Thu, Dec 27, 2007 at 10:06:05 AM
View Title Extension Lines |
Fri, Dec 10, 2010 at 3:03:17 AM
Members: | 1999805 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
