111 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit sloped glazing & angled curtain grids problem
Tue, Jun 5, 2012 at 6:14:34 AM | Revit sloped glazing & angled curtain grids problem
aeerdogan
Hi,
I have this little problem. I need to make a glass cover for the entrance of the building. I decided to try it by using roof > sloped glazing. In fact I made it completely flat. As you can see in the attachment, it does not lie parallel to the project.
But when I try to make curtain grids with the curtain grid tool, it always tries to place grids paralel to the "world", not the object. To overcome this I tried;
1. Placing a workplane on the object, and then rotating it paralel to the object. But curtain grid tool does not care about the WP.
2. Selected the glass roof while there are no grids, i hit the grid alignment on-screen button, rotated the grid alignment, but it did not rotate.
Can you tell me any hi,nts about this simple matter, I just want to place curtain grids parallel to object outline. I use RAC 2013 by the way.
Thanks in advance.
Tue, Jun 5, 2012 at 6:29:23 AM | Revit sloped glazing & angled curtain grids problem
4 Stars: 201 Votes
You are doing something wrong, select that curtain grid and check the properties, there are 2 rotate parameters to UV grids...
Tue, Jun 5, 2012 at 9:47:30 AM | Typhoon
aeerdogan
Quoting Typhoon from 2012-06-05 06:29:23
Well actually there are no properties. (see image attached)
Tue, Jun 5, 2012 at 12:33:32 PM | Revit sloped glazing & angled curtain grids problem
4 Stars: 201 Votes
Look again carefuly --- you are doing something wrong...
Edited on: Tue, Jun 5, 2012 at 12:34:55 PM
Wed, Jun 6, 2012 at 5:03:59 AM | Revit sloped glazing & angled curtain grids problem
aeerdogan
Well thanks for that reminder but for that the object has to be on an exact angle, I have to measure it, then enter it in the properties of the object. Then use the curtain grid tool.
Like for this case that angle is 58 degrees.  But I don't know if it is not 58.376 degrees. You know what I mean? I was looking for a direct way to put grid lines manually, parallel to object.
Wed, Jun 6, 2012 at 6:02:18 AM | Revit sloped glazing & angled curtain grids problem
4 Stars: 201 Votes
"But when I try to make curtain grids with the curtain grid tool, it always tries to place grids paralel to the "world", not the object. " - Is now PARALEL to the object or not???
"Like for this case that angle is 58 degrees.  But I don't know if it is not 58.376 degrees. You know what I mean?" - No I don't, You don't know what the angle is? or it's 58 deg. or 58.376 deg... if you don't know who else knows? Use the Dim. Angular tool and clarify, then change the "Grid1 and Grid2" with the right angle.
Wed, Jun 6, 2012 at 12:04:12 PM | Revit sloped glazing & angled curtain grids problem
aeerdogan
First of all Typhoon you don't have to answer the question. So don't try to be funny like you did there, ok? You can simply say that you don't know any way else to do this.
Well, I guess I have to answer like you did, but no, I can't be less polite, sorry if I sounded unpolite, English is not my native as you can easily figure.
1. Let's say Revit dim shows it as 58 degrees, but if you select the dim, in properties you see that it is 58.3768 degrees right? Well this is why revit shows us that four digits, in fact it may be 58,3767626517625781625 degrees, continuing to infinity.
2. This makes sure that by typing the value by hand, the grid will NEVER BE PARALLEL to the edge.
3. I think this may cause some annoyances while snapping, drawing, measuring or whatever etc.
4. I'm sure you were trying to be helpful, but your attitude may also cause other readers think there is no problem here, and it is only my fault. But sure there is this "little" problem as I mentioned in the first place.
Wed, Jun 6, 2012 at 12:36:06 PM | Revit sloped glazing & angled curtain grids problem
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is this an existing building?  If not then why are u making an angle that is not accurate, or how do you end up with such an odd angle?  Either way you can set your Unit Formats up so that it runs out to the end of your decimal places.  If your angle is off 0.000000000000000000001 degrees I hardly think that would cause any annoyances.
Wed, Jun 6, 2012 at 12:52:49 PM | Revit sloped glazing & angled curtain grids problem
3.5 Stars: 395 Votes
You are way off base!  Typhoon was not being impolite.  This is your model and you should know what you have.
Wed, Jun 6, 2012 at 1:05:34 PM | Revit sloped glazing & angled curtain grids problem
4 Stars: 201 Votes
I want to answer the question, do you think i was funny and impolite? why?
Whatever... I put the dim. ang. with 11 decimal places and the grid lines still "paralel" with the object like you can see, so, are they paralel with the object or not? I know you gonna say: "... in fact it may be 58,3767626517625781625 degrees, continuing to infinity." but do you think is good enought? after all you are creating architectural plans not watches....
Edited on: Wed, Jun 6, 2012 at 1:06:46 PM
Wed, Jun 6, 2012 at 1:14:48 PM |
#11
aeerdogan
Quoting teafoe5 from 2012-06-06 12:36:06
Thanks, and yes it is an existing building, and you must know well sometimes people don't draw by entering angles, they draw by connecting 2 existing points whatever the angle is. In short it is not MY angle.
And WWHub that is only your idea. You think I'm out off base, and I think Typhoon was impolite. So?
I tried to (in fact still trying) positively explain the issue, and what I aim, in all detail, yet simplest as possible. So as I understand there is no way to align these parallel. Thanks for all the advices, it is time to call it off, I don't want to be in such conversations.
Wed, Nov 13, 2013 at 10:35:24 PM | Revit sloped glazing & angled curtain grids problem
#12
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
It's quite simple.. just use slope arrow..
Watch this.
http://youtu.be/9vCr1b2JtWA
want more?
You can get more tips at Enjoy Revit
Thu, Feb 25, 2016 at 11:33:26 PM | Revit sloped glazing & angled curtain grids problem
#13
daniu
4 Stars: 1 Votes
I know it's a little late but this may help someone else.
The problem is that your roof is flat and Revit doesnt know what to align the grid to. Just tick "define slope" on one of the roof boundaries and set it to "0°", the grid will then align to this boundary.
If you try to enter the angle manually - say you put in 57.34°, but the angle is actually 57.3429084907829803°, you won't be able to dimension it.
sloped glazing in schedule
Wed, Jun 17, 2009 at 10:18:35 AM
Random Diagonal Curtain Grids in a Curtain Wall
Wed, Jul 6, 2011 at 6:57:03 AM
Tell me again how to make "sloped glazing" look like metal roofing?
Wed, Jun 11, 2008 at 9:43:34 AM
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
Sloped Glazing is Missing Mullions
Tue, Apr 8, 2008 at 3:18:01 AM
Page generation time: 2.9891
